 DST1
			DST1
			09-30-2016 03:05 PM
I'm trying to convert a Lookout 6.1 file to 6.7.1 but keep getting recompile errors. I've opened the source file and tried to fix the errors in notepad, but some of the syntax errors are not there and it doesn't make sense. I've also fixed some of the errors only to have new errors appear when i recompile. I'm hoping an administrator will take a look at my file to see if they can do the conversion.
10-04-2016 07:10 AM
Here is the 6.1 file in question...
 bovey_lee
			bovey_lee
			10-08-2016 03:13 AM - edited 10-08-2016 03:28 AM
I tried to open your source file in Lookout 6.1, however it failed, a warning window pop up, saying Backup Files: Could not load class.
Maybe you have used some backup files which are not included in Lookout.
