Lookout
Can you take a factory alarm and turn it into an event?
(4,158 Views)
I think you need to be a bit more specific, are you talking about an Alarm thats in a building that makes a noise or an alarm in lookout ?
(4,153 Views)
I have a "No Communication from Mod Bus Secondary" alarm that I would like to make an event in the log.  If I can't do this, can I make this a lower priority?
(4,148 Views)
You can use Event object to programmatically log a event when the alarm occurs. For Event object's configuration,
Trigger = $Alarm.update and $Alarm.message="No communication response from Modbus secondary"
But the alarm still exists. Its priority can't be changed.
Ryan Shi
(4,134 Views)
Thanks for all your help with this.
(4,129 Views)
