Lookout
Cannot lauch project, class error messages
The project was originally configured in LookoutDirect, then converted to Lookout 6.2.
One one computer I have a seperate Runtime and Development packages.  This computer has been working satisfactoraly for two months.
Insatlled second runtime software on computer two, but cannot launch project because of class errors.
Can I copy the entire National Instrument folder from one computer to the other to correct this.
thanks
John Peterson
(6,663 Views)
You need to copy the appropriate driver over.
DO NOT COPY THE WHOLE FOLDER!
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(6,660 Views)
I guess you installed the DirectLogic PLUS on the dev/runtime computer. You need to install it on the second computer, or maybe just copy the driver file, .cbx file. I don't remember the name of the file.
Ryan Shi
(6,635 Views)
DLPlus.cbx last i remember
(6,611 Views)
Accepted by topic author JohnnyP
Problem solved
Believe drivers are DSComm4.cbx and Meter4.cbx, but don't bother moving them.  Tried every conceivable location.
You must INSTALL the driver on both computers.
Driver from Automation Direct
(PC-DL-PLUS LOOKOUT DIRECT PLUS DRIVER OBJECT SFTWRE)
From the responses I think their is more than one with the problem.
Also make sure the tages are not pointing to the computer name.  Tag path should start with "..\" or "..\..\" (test on yours) to work on both computers.  Computer name appears depending on how you drill down to the PLC address.  This doesn't stop the project, just gets rid of the red X's on the second computer.
Thanks for your responses
John Peterson
(6,604 Views)
