Lookout
Cannot show the Hypertrophy - Lookout 6.5
I tried to add a hypertrophy object to show the water level. Attached is a picture to show what I have set in the program. When I run the program and move the slider up and down, I didn't see the red line to show the value. Can anyone tell me what is the reason I cannot show the line? Thank you very much.
(5,709 Views)
Solved after I setup the data member.
(5,707 Views)
