Lookout
Lookout 64-bit and WIndows 7 !!!
Status of 64-bit Lookout release and Windows 7 compatability testing?  Testers needed?  Note that next version of windows server (2008 R2), will only release in 64-bit versions!  I need Lookout to work on these servers!
Cheers,
Ed
Message 1 of 8
(10,019 Views)
The general testing if done, if the program works in Vista it works in Win7.  Im running lookout in 64-bit machines as we speak with very minor issues, which are posted here.
Does lookout need more than 3.25GB of ram?
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
Message 2 of 8
(9,993 Views)
Lookout is supposed to be running fine in 64 bit machines. But windows 7 has not been tested. The problem is that we cannot catch up with Microsoft to support new OS as soon as it is released. Usually there is a delay.
Ryan Shi
Message 3 of 8
(9,985 Views)
Is Lookout scheduled for Native 64-bit rewrite?  I want to stop seeing system logs with errors of services that did not properly register or load, even if they don't "seem" to be required.
Message 4 of 8
(9,920 Views)
What's your current OS on which you have the service error?
If it is Vista 64bit, it is a bug we will fix. Lookout should run on Vista 64bit without any problem.
If it is Windows server 2008 server 64bit or other OS, we would probably like to fix. Actually we have fixed a bug recently which causes problem to the Citadel and other service on windows server 2008 OS. I'm not sure if it is exactly the same one.
Ryan Shi
Message 5 of 8
(9,901 Views)
All my Lookout servers and clients are now running  server 2008.  The server OS is simply more stable and reliable plus it allows: 1. Admin of the machine via remote desktop without logging into console or locking the console.  2. Remote control of the console without locking the console on disconnect.  These features are all vital in my opinion for a production Lookout machine.
It is way past time for National Instruments to seriously reconsider their lack of official support for server OS's.  The mere implied tasking of software such as Lookout just screams SERVER OS.
Please point me to or send me any fixes you have for Lk 6.2 on server 2008, 64-bit Windows, or virtual machines.
Ed
Message 6 of 8
(9,898 Views)
Please also be aware that the next version of server (2008 R2 - this summer) and forever after, will only ship as 64-bit OS.  No more native 32-bit...gone!
Message 7 of 8
(9,851 Views)
I'm trying to run Lookout 5.1 on a Windows 7 Machine. I've tried setting all Applications to XP Compatibility and even changed settings in the Bios hoping that it would fix the issue. However, no matter what I do it just starts up and hangs. Is there any special magic to make Lookout run on Windows 7?
Thanks.
SCADA Programmer at the Coachella Valley Water District.
Message 8 of 8
(8,125 Views)
