Lookout
Client Control of Server Process
How do I control a real world output via the client process? I have a Lookout Server V6.2. The server process has a switch with the following configuration (Position Source = Remote: “..\PLC.Y1”) which controls a real world PLC output.  I put a switch in the Client process and set the Position Source to reference the server process switch. This allows the Client switch to change when the server switch is changed. However, I need the Client switch to control the Server switch. In the end I would like to be able to control the switch from either the Server or the Client. It does not necessarily have to be a switch as long as I can control the Real World output from either the client or server. Any ideas would be much appreciated.
(5,692 Views)
In client process, the source should be like "..\Switch1.value", not just "..\Switch1"
This tutorial may help you. http://zone.ni.com/devzone/cda/tut/p/id/3989
Ryan Shi
(5,659 Views)
