Lookout
Conflicting Ports
I've port-forwarded UDP port range 1024 - 65535 for the Lookout Client Access. I now have a device (for remote camera telemetry) that must use UDP port 1025.
Would there be a problem if I were to exclude UDP port 1025 from the above range for the Lookout Client Access?  Can this port be shared between Lookout and the remote camera device?
(6,131 Views)
Accepted by Zog626
It doesn't matter. Logos doesn't need all the ports, but just find the available ports in this range.
Ryan Shi
(6,118 Views)
