Use OPCClient object in Lookout. Set up the OPC Server, including the configuration of items, then the OPCClient is able to connect the OPC Server and read or write items. In this way, Lookout just talks to the OPC Server. The communication with the PLC is handled by the OPC Server.
	Ryan Shi
