Lookout
Could you please tell me, how can you, using Lookout and Field Point, program on/off relay actions using a calendar?
It´s a on/off illuminating ssystem control. Shure the user will need a calendar programing tool to program weekdays, holidays, etc. on of functions.
(3,247 Views)
Hi Galileo,
See the following for Lookout side of things:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000DBE90000&USEARCHCONTEXT_CATEGORY_0=_9_&USEARCHCONTEXT_CATEGORY_S=0&UCATEGORY_0=_9_&UCATEGORY_S=0
As for FieldPoint, you can talk to it from Lookout in couple of ways -- either directly using the native FieldPoint object, or via OPC using the OPCFieldPoint object.
Based on the timers from above, you would turn On/Off the relays (on the RLY-420 module of your FieldPoint).
That's in a nutshell. Write back if you have specific questions.
Good luck!
Khalid
(3,247 Views)
Hi Galileo,
I agree with Khalid, and recommend using the OPCFieldpoint object. I've had much better luck communicating using OPC as opposed to the Fieldpoint object.
Vineet A.
(3,247 Views)
