Lookout
Crash during Compile in Lookout 6.1
The crash during compile has been fixed. I will upload the updates to website soon.
But this problem is not related to the driver. It crashes before you see the panel. So I think your problem is not the same one.
Does the crash always occur when you enter the edit mode? What's your lookout version?
Ryan Shi
Message 11 of 28
(4,338 Views)
My client has version 6.1 running on laptop with window xp. This problem is unique to his PC. I too have a laptop with window xp, but the application does not crash on my machine.
The application involves 2 Lookout  .L4P  process files. The first process file launches just fine; it has a loader object in it that launches the 2nd process file (which has the direct logic communications driver object in it. It too launches just fine--but as soon as you perform any acitvity such as putting Lookout into edit mode, or clicking on a pushbutton object, etc. the Lookout program locks up.
Message 12 of 28
(4,331 Views)
could you upload the process to ftp://ftp.ni.com/incoming
Let me try if the hang will happen on my computer.
Ryan Shi
Message 13 of 28
(4,311 Views)
How do I upload to the ftp://ftp.ni.com/incoming/.  I tried but was not successful.
Message 14 of 28
(4,293 Views)
Just input ftp://ftp.ni.com/incoming/ in IE, and then copy paste.
Make sure that the uploaded files are not being used by other application.
Ryan Shi
Message 15 of 28
(4,289 Views)
Ok Ryan, I have put the file up into the /incoming folder. It is called      arnet.zip
I think you are right. I changed the driver to a modbus driver and the problem is still occuring on my clients laptop.
Charlie
Message 16 of 28
(4,257 Views)
I want to confirm that the process is loaded correctly on client laptop, right?
If you don't touch anything, will it run without problem? As soon as you touch anything, it freezes?
I don't see this problem on my computer. At least it runs fine without hang or crash.
Can you also upload the other process? I only see 1 process, but you said there are two.
I see the source file version is 6.0.1, but not 6.1. What's the actual version on your laptop and client's laptop? If it is 6.0.1, I suggest you to upgrade to 6.0.2 first.
Ryan Shi
Message 17 of 28
(4,246 Views)
We just purcahsed some new Dell Precision PWS690 with Intel Xeon CPU E5345 @ 2.33Ghz with 3.25 Gb of RAM running Windows XP Pro with Service Pack 2.
After installing Lookout 6.1 and trying to open up my server file that uses the direct logic drivers, Lookout is hanging up with the follwoing error data from event viewer:
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 48 61 6e 67   ion Hang
0010: 20 20 6c 6f 6f 6b 6f 75     lookou
0018: 74 2e 65 78 65 20 36 2e   t.exe 6.
0020: 31 2e 30 2e 34 39 31 35   1.0.4915
0028: 33 20 69 6e 20 68 75 6e   3 in hun
0030: 67 61 70 70 20 30 2e 30   gapp 0.0
0038: 2e 30 2e 30 20 61 74 20   .0.0 at
0040: 6f 66 66 73 65 74 20 30   offset 0
0048: 30 30 30 30 30 30 30      0000000
This problem is specific to this computer because I can open this server file on our older computers and my laptop. Also, we bought 4 of these computers and when I tried to open this file on these other computers I had the same problem.
Jason Phillips
Message 18 of 28
(4,158 Views)
Do you apply the fixed lkworks.dll I gave you last time?
If you open the .l4p file, will you get the hang?
Is it a 64 bit computer and 64 bit XP? or 32 bit?
Ryan Shi
Message 19 of 28
(4,149 Views)
I did apply the lkworks.dll file you gave me and the lookout.exe file you gave me as well.
It is hanging when loading the .l4p.
I tried to compile it to see if it would load and it appears to compile fine but when I get the "loading" dialogue box, Lookout just stays there and hangs.
It is a 32bit computer and 32 bit XP.
Jason Phillips
Message 20 of 28
(4,135 Views)
