Lookout
DNP3 Master connection via Ethernet with Lookout
I want to know if it is possible to make a DNP3 Master connection via Ethernet in Lookout?
Because in the trial version it is not possible.
Thanls in advance.
(5,984 Views)
We use the Lookout DNP driver to communicate over ethernet to RTU's, but we have to use a seperate software helper called a serial to IP converter. We assign the driver to a comm port in Lookout and then assign the destination IP address to the comm port in the Serial-IP software. My only problem is that me end devices support Trip/ Close pairs and Lookout does not.
(5,960 Views)
