Lookout
Data visible via hypertrend missing in ODBC Traces Table
I am trying to pull data from the Citadel database into Access using the ODBC driver from Lookout. I am running Lookout 5.0 on Windows 2000 Advanced Server. When I query the Traces table, not all of the tags that I am currently logging show up. In fact fewer than half are available. How can I retreive the data that I know is there if I can view it with Hypertrend Object?
(2,908 Views)
You might run into a timeout? You should contact National Instruments Support team to get more information about how to tweak the ODBC driver to extend the timeout.
Hope they can help you further
Roland
PS: Mention KnowladgeBase: 2TFEH4Q2
(2,908 Views)
