Lookout
Has anyone used the labview report generation toolkit to generate reports using Lookut data? If so, has it been beneficial?
I am runnning Lookout 5.0
Jason Phillips
(3,118 Views)
I have collected data before in Lookout, but never used that data with the report generation toolkit. I have used the report generation toolkit many times with data generated in different environments. The toolkt just gives you an easy-to-use interface to programmatically create reports on my data. So, to answer your question, I have found it beneficail. I find it a very simple way to generate reports from data gathered anywhere.
(3,118 Views)
Thanks. That's what I was looking for - an easier way to generate reports.
Jason Phillips
(3,118 Views)
