Lookout
Date format display in experssions
Dear Experts,
I am trying to use an expression in order to display text, integer number and Date format number, this result is “Daily KV MAX is 33.21 kV @ 42189.4” but I need display last number in date/time format and I expect like this “Daily KV MAX is 33.21 kV @ 09:38”, How could is fixed?
Thanks in advance
Danesh
Ps: this is my Expression, “"Daily KV max is"&..\Kv_daily_max&"kv @"&..\kv_daily_max_time”
(5,186 Views)
Have you tried using the text function?
""Daily KV max is"&..\Kv_daily_max&"kv @"&text(..\kv_daily_max_time,"dd/mm/yyyy hh:ss")"
The text function can use any string available to a numeric display.
(4,880 Views)
Accepted by Danesh
Excellent, it is solved!
(4,855 Views)
