 Jen Greene
			Jen Greene
			08-09-2005 07:37 PM
 erblock
			erblock
			08-09-2005 09:45 PM
If this is Lookout 6, you will need to re-register because your Computer ID used by NI to generate your license key has likely changed due to the major component/configuration change generated by a motherboard replacement.
Good Luck,
Ed
 Khalid
			Khalid
			08-10-2005 01:00 AM
I don't think this is a Lookout message. Are you using any ActiveX controls from OPCSystems? They may have tied their license key to the motherboard (typically to the MAC ID when the network card is built into the motherboard.)
Do you get the same message when you open a new Process in Lookout?
-Khalid
