Lookout
Why demobox for lookout basics is not communication?
(3,941 Views)
Do you get any alarms?  If yes, what do they say?
-Khalid
(3,939 Views)
In the alarms window: No communication response from modbus secondary.
(3,927 Views)
Are you using the default settings for the Modbus object?  Also make sure that the serial cable is a straight one (as opposed to a null-modem one).
-Khalid
(3,919 Views)
yes using the default settings for the Modbus object
(3,913 Views)
Are you using a staright-through serial cable?  Can you verify that the COM port itself is functioning correctly.  You can do this by doing the "loopback" test:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YFtECAW&l=en-US
Hope this helps,
-Khalid
(3,901 Views)
