Lookout
DignosticFile= setting in .ini file not working?
When editing Lookout.ini file in Lookout 6.1 and adding setting as follows:
[COM9]
DiagnosticFile=C:\com9.txt
or
[COM3]
DiagnosticFile=C:\Program Files\National Instruments\Lookout 6.1\com3.txt
No logs are created for the named COM port.
I know I used this feature sucessfully back in Lookout 4.5 and earlier, maybe even in Lookout 5.1.
Please confirm and help!
(6,028 Views)
You can configure this in Lookout. Go to Option->Serial ports, select COM9, check "Enable", input the diagnostic file path, "Accept".
Close Lookout, then open lookout.ini. You will see the following codes.
DiagnosticFileEnable=1
DiagnosticFile=c:\test.txt
DiagnosticAllHex=1
DiagnosticTimeStamp=1
DiagnosticTimeStampDateFormat=73
So, you need to add DiagnosticFileEnable=1 to make it active.
I'm not sure how it worked in Lookout 4.
Ryan Shi
(6,019 Views)
Hi Ryan,
Thanks for the help...
However, Lookout 6.1 will not actually write the file!  I have tried the default path and simple c:\logcom3.txt type of paths with full permissions....No LUCK!
Did you folks break this in LK 6.1 ?
Ed
(6,011 Views)
I tried Lookout 6.1. It can log the diagnostic file without any problem.
I just follow the steps I said, select the com port, and enable the log.
Which driver do you use?
Ryan Shi
(6,007 Views)
Hmmm....
The settings do get added to the .ini file, but the file never appears.  How large is the buffer that is used and will it wait until the buffer is full to open and write the file?  The unsolicited ASCII is only taking in 26 bytes every 4 seconds.  Maybe this is the issue?  Also, there is no outgoing traffic, only unsolicited incoming.
Message Edited by erblock on 12-05-2007 10:16 PM
(6,003 Views)
I think I have reproduced the problem.
Try this example. I'm able to log the file.
But when I use labview on another computer to send Ascii messages to Lookout, the log file won't be generated.
I will look into this.
Ryan Shi
(5,999 Views)
This seems a bug in Lookout. Lookout is able to log all the data outgoing, and all the response data. But the unsolicited data, which is not recognized as response data, won't be logged.
Ryan Shi
(5,993 Views)
