Lookout
Lookout with SLC500 using 1747-PIC
Has anyone found a way to have Lookout communicate with an Allen Bradley SCL500 using a 1747-PIC adapter, directly into the computer's serial port using one of the built in Lookout AB SLC500 drivers? I can get it to work using DDE/OPC, but I prefer to just use one of the built-in lookout plc drivers. The KE/KF/Serial drivers apparently do not work with this connection.
If not, does anyone have a recommendation on how best to utilize the DDE link? I just simply created a Lookout DDE Link to pick the various addresses from the PLC, was wondering if there is a more efficient method of doing this. I only need about 20 values but they are scattered throughout the PLC's memory.
Thanks.
Message 1 of 8
(7,229 Views)
No, you can't use Lookout's built-in drivers with 1747-PIC.  All the available ways to connect to SLC500 are described in detail in Lookout's help.
Ryan Shi
Message 2 of 8
(7,218 Views)
I have recently started using ethernet to communicate with an Allen Bradley SLC 5/03. I was told this
could not be done however that is not true. This can be done and is very easy to do. The cost for this
application is half the cost of an ENI module and works very well. Look at DIGI One IA. If you have any
questions just ask!!
Message 3 of 8
(6,528 Views)
Originally Lookout SLC500 object doesn't support any Ethernet connection. Then we developed the ethernet driver for SLC5/05. I guess, but not sure, that we didn't test with SLC5/04 or SLC5/03, and found there was something different in 5/04 or 5/03, then we officially say that only SLC5/05 supports Ethernet connection, just like what the help file said.
I also saw some messages from customer that the Ethernet communication with 5/04 and 5/03 are fine. It is good, but I'm sorry that maybe we need more tests to verify.
Ryan Shi
Message 4 of 8
(6,522 Views)
One question, how do you connect to the PLC?
Ryan Shi
Message 5 of 8
(6,519 Views)
The connection is a simple RS232 connection. 2 to 3 and 3 to 2 with 5 being the ground. At first I started using
a null modem connection but later found out that the three wire 232 connection worked just the same.
Message 6 of 8
(6,515 Views)
But you said you started to use Ethernet connection to 5/03.
RS232 or Ethernet? I'm confused.
Ryan Shi
Message 7 of 8
(6,512 Views)
It is very simple. It looks like a 232 connection but it is over the ethernet. It is a virtual 232 connection. It works
just as well as the straight ethernet connection I use with our PLC 5's and the SLC 505. I told you in the first
posting what module to do this. Lookout thinks it is a serial connection but it is over the ethernet hundreds
of feet away!
Message 8 of 8
(6,510 Views)
