Lookout
Distributing Lookout to an NT domain using Group Policy
Hello all,
I need to distribute Lookout to several workstations that belong to a Windows2003 domain.  I would like to use Active Directory to push an .msi package to be centrally managed.  Is Lookout avaliable as an .msi package, or is there a preferred method for repackaging into a redistributable package?
thanks,
-scott
(3,155 Views)
Hi Scott,
When you call the setup.exe in the Lookout install CD, it calls the .msi files of all the components that get installed with Lookout. You can view these .msi files in the installation CD. However, I am not aware of any way to centrally manage these .msi pacakaging with Active Directory.
Prashanth
(3,138 Views)
