11-20-2005 10:34 PM
11-21-2005
04:04 PM
- last edited on
11-14-2025
04:10 PM
by
Content Cleaner
Alan,
You definitely will want to back up your process files before uninstalling -- these include .l4p, .l4t, .lka, and .lks files. Additionally if your databases are important it would be a good idea to archive them, this process is talked about here.
Other than that you should be able to uninstall lookout 6.0 using Add/Remove Programs and going to National Instruments Software and choosing Lookout from the list. I would then suggest rebooting your computer and then installing 6.0.2.
Please let us know if you have further questions.
03-13-2006 05:44 PM
03-14-2006
11:03 AM
- last edited on
11-14-2025
04:11 PM
by
Content Cleaner
Hi Alan,
If you images were just images from the default Graphics directory, you should have no problem. However, if you used images from the Image Navigator or imported custom graphics, these will need to be added to your new installation. You can either create a subdirectory in the Lookout/Graphics directory, put your images there, and relink all your images to look at the new folder, then copy this folder and put it back to that same location after reinstalling. However, if you are simply upgrading on the same computer, it's probably easier to copy your entire Graphics directory to a safe location, then uninstall/upgrade, then copy the backup Graphics folder over the new Graphics folder after reinstalling.
