Lookout
Espression Object
I’m trying to use an Object Expression (not the plain Insert Expression) for scaling the value of a Pot Object named “TestPot” before log into the database in order to have the proper scale record. Because some conditions of my design, I need that the Pot swing from 0 to 4095 (simulating an analog input), and using an Expression Object (TestExp), to scale the Pot’s value to a range –100 (MinPot) to +100 (MaxPot). After this scaling, I would like to log the Expression’s value and display it by one Hyper-trend.
After some work, I tried many ways but I can’t see the Expression in the Hypertrend.
Attached there is a file containing this example.
Is here something wrong?
(3,369 Views)
I guess you show TestExp.value in the hypertrend. However, (expression) objects just have an implicit datamember. Therefore, you should just add TestExp to the hyperternd configuration.
Hint: Browsing to the datamember instead of typing is a cool feature of Lookout 🙂
Hope this helps - let us know.
Roland
(3,369 Views)
Can't this scaling be done with the Edit Data Member Configuration?
(3,369 Views)
