Lookout
Exporting Lookout Graphics & Importing
I need to export some graphics from lookout,modify them in Paintshop Pro and import it back.Is it possible to export graphics from lookout?Also Cut & Paste doesnot seem to work out from Lookout.
(3,823 Views)
INCO,
If you use PSP, browes to the "National Instruments/Lookout 5.0/Graphics" directory all the graphics are located here. You can open up what ever graphics file you need, edit it, then save the file in its current location.
(3,823 Views)
Thanks for the reply.I wish it was that simple.What I need to edit outside of Lookout is a Process Graphic Page which is a collection of smaller graphics files using 'Insert Graphics.....'.
I have five processess controlled by each process graphic.I need to create one 'overview' graphic taking parts from each five graphics.If I do that in Lookout it does not resize to acceptable scale and it distorts the graphic.
Regret not explaining in detail earlier.
(3,823 Views)
You will not be able to edit a process panel outside of the Lookout enviroment, in order to create the overview process panel you are refering to, you will be limited to the editing/copying tools available in Lookout.
Best Regards
Andre Oliveira
(3,823 Views)
There are many, many things that could be made easier by being able to copy displays from one panel to another - why is this not implemented?
(3,823 Views)
