Lookout
Expression for datatable cursor??
I wish to use an expression (variable) that indicates which cursor I'm interested in (for a datatable). Here's an example: if I have an expression called CN which is equal to one, I want to be able to reference members in this style:
Datatable.A.CN
any way to do this???
(3,641 Views)
A dynamic symbolic link would work. The expression would be close to your example. It would be "Datatable.A."&CN and if the value of CN changes so does the cursor used to reference column A. More info is available in the online help file.
(3,642 Views)
A greeting beforehand, wanted to ask like can be reslver the problem of which when using the cursor in the Hypertrend of Lookout 6, always shows the value of zero.  Even though this updating the data.  Thanks.
(3,577 Views)
