Lookout
dde tables
Can anyone shed some light of the following problem I am using lookout 5.1 and the os is XP pro I have a data table running in lookout with aprox 1300 links to a excel workbook there is no data written to the workbook so lookout is the client and excel the server problem is everything works fine until you change from development to runtime or reopen the process then there is no data received there are no alarms and the dde can be re established by double clicking any cell in excel and pressing enter or by clicking Object modify select dde table not changing any of the properties but just click ok and everything works fine again.
Message 1 of 1
(3,351 Views)
