Lookout
Flickering effect displaying panel with enablerestoreoption set to false - Lookout 6.6
Hi folks
There is a side effect in the use of the enablerestoreoptions of the panel objects: a difference in the way the panels are diplayed if the enablerestoreoptions is FALSE. You can see a flicker effect much more bigger than the option is TRUE.
Look at the attached project. In it there'a a little readme file explaning the project.
Thanks for the time spent to examine the project.
Mario Fanelli
(5,555 Views)
I see the flicker effect.
Ryan Shi
(5,550 Views)
