Lookout
object explorer always on top - lookout 6.6
Hi folks,
There's a is a irritating thing that occour when you develop a project in lookout 6.6: the object explorer windows always stay on top and can cover the other windows expecially the edit expression, edit connections and edit data member windows. if you use multiple object explorer windows, you must move the edit windows constantly.
Thanks and have a nice day
(6,253 Views)
I don't remember clearly. Did it happen with previous version?
Ryan Shi
(6,245 Views)
Hi Ryan,
It happes in the 6.6 version The 6.5 wrks correctly.
Bye
(6,242 Views)
Hi Ryan,
Look at the screenshots attached.
Bye
(6,240 Views)
I see. It's probably because the feature added to 6.6. I will check if we can change to previous behaviour.
Ryan Shi
(6,236 Views)
Thank you, Ryan
(6,234 Views)
