Lookout
GE RX3I with Lookout 6.7.1
I need to convert an existing Lookout 6.7.1 application (350+ tags) from a GE SNP Serial driver (GE_Series90)  to GE Ethernet (GE_VersaMax?).  Is there an easy way to work through the process?
Thanks, Win B.
BWC Systems
(3,235 Views)
I think there's no shortcut to convert GE SNP Serial driver to GE Ethernet driver, these are two different ones in Lookout, so you should configure it again.
(3,202 Views)
