01-06-2017 11:59 AM
Is it possible to set up two MODBUS Drivers in Lookout and communicate with two devices, one on each com port? Also can I use the same Register Number on the separate links?
01-09-2017 02:44 AM
Yes, Lookout allows us to set up two Modbus drivers to communicate two devices simultaneously. You can also set up two channels to read the same Register and show them on the panel, that function can be realized.
