Lookout
MODBUS over two serial ports.
Is it possible to set up two MODBUS Drivers in Lookout and communicate with two devices, one on each com port? Also can I use the same Register Number on the separate links?
SCADA Programmer at the Coachella Valley Water District.
(3,173 Views)
Yes, Lookout allows us to set up two Modbus drivers to communicate two devices simultaneously. You  can also set up two channels to read the same Register and show them on the panel, that function can be realized.
(3,118 Views)
