Lookout
How can I install and run lookout 6.1 on windows server 2008 64-bit without errors?
How can I install and run lookout 6.1 on windows server 2008 64-bit without any errors?
I was unable to start the lookout applcation after I install the lookout 6.1 on windows server 2008 64-bit.
(error code: 0xC0000142). Please help!
(6,592 Views)
Use HyperV and create an XP virtual machine.  I have run 6.1 on 2008 (x64), on 2008 R2 6.2 works okay.
Mike
Forshock - Consult.Develop.Solve.
(6,587 Views)
You could also check the manuals here to make sure that you have step by step way of installing it. 🙂
http://sine.ni.com/psp/app/doc/p/id/psp-641/lang/en
(6,564 Views)
hey
ya i have the same prob here.. !    i tried the virtual machine thing but dosent help .. can any one reply me quickly .. please .. thanks
(6,558 Views)
try this one
(6,554 Views)
This will pobably do http://joule.ni.com/nidu/cds/view/p/id/1051/lang/en but the major issue is that you should concentrate and read the instructions carefully. My two cents.
(6,532 Views)
I am not sure how those responses were of any help (the two above).
I can confirm again, that I have run 6.1, 6.2 & 6.5 on Windows Server 2008 & 2008 R2 without major issue.  May want to try another machine to test.
(6,506 Views)
