Lookout
How can I log the active state of an Alarm object to HyperTrend?
The Alarm object has an active member but does not seem to have any way to log that active state so that I can display it on a HyperTrend graph.  Am I missing something?
(5,769 Views)
In edit mode use 'edit data member configuration' to log the 'active' datamember to Citadel.  It should show in the trend from that moment on - unless Citadel is corrupted.
(5,763 Views)
Thanks!  That works well.  It's so simple that I must have had a serious brain-fade to have missed it!
(5,760 Views)
