Lookout
How can I launch an executable of another application from Lookout?
(3,098 Views)
Jasy,
you may use the "RUN" object. This object allows you to execute applications from within lookout. In order to execute DOS command you might generate a *.bat file and run it.
JPSS
(3,098 Views)
