Lookout
state file does not update
The l4t (state file) does not update on my system unles the app is saved. All settingins in "modify process" are set to capture every 1 min. Have also tried longer time intervals with no luck. Help i appreciated.
(3,081 Views)
It's strange that the state file isn't updating at the rate that you are specifying.
Does this happen even after restarting the computer?
Has it ever updated without saving in the past?
Do you notice the same problem on a different computer?
Vineet A.
(3,081 Views)
