Lookout
How can I print out the objects with the configuration and connections? I want to document my programming (configuration) on paper.
In my question, I forgot to indicate, that I am using Lookout 6.1. I am using Lookout in a technical school with my students. Therfore I need to print out
the configuration of the connection browser to document the students work. But I can find no function to print out any objects with there configuration.
thanks for any help.
Claude
(6,431 Views)
The datamember configurations can be exported. In edit mode, File->Export Process Data Members...
But the connections cannot be exported.
You can open the .lks file by notepad, there you will see the source codes, including the connections you configure. But you need to extract them manually.
Ryan Shi
(6,416 Views)
Accepted by wolcl
Thanks for the tip. I have tried out and it is OK. But I think, that a structured printout ist missing in the software and should be added in any next versoin.
Claude
(6,407 Views)
