Lookout
How do I communicate with an AB micrologix 1200 (DF1 protocol) with Lookout 3.8?
Is ther an add on driver available that I can use?
(3,501 Views)
There's no MLogix 1200 driver for Lookout 3.8, at least not from NI. But, you can use the OPCClient Object in Lookout 3.8. Which means you'll need the OPC Server from AB-Rockwell Software: RSLinx, full version.
Rgds,
Khalid
(3,501 Views)
