Lookout
How do I tell lookout to write a modbus force coil command?
I want to force a coil in modbus using Lookout. Where do I enter the function command. I can read the PLC registers but for the life of me can't figure out how to force a coil.
(3,213 Views)
Addendum to my question. Im trying to use a Zetron 1732 controller and I want to force a digital output on a 1730 rtu using lookout connected to the controller. Lookout 5.0
(3,213 Views)
You will have to connect a logical signal (PushButton, Switch, etc.) to your coil in the connection editor like this :
Modbus1.1 = Switch1
Where Modbus1 is your Object, you're writing to coil 1, with Switch1.
Please write back if I did not understand your question correctly.
Khalid
(3,213 Views)
