Lookout
Is there and IPMODBUS
What we are tring to do is setup our system to use the Freewave Radios in UDP mode and we found the IPASCII but we dont what ASCII comeing out the other end. This is the first time we have experimented with this idea so we are a little unexperinced.
Thanks Whit
(3,566 Views)
Hello Whit,
What do you mean by "coming out the other end?" Maybe you can explain your setup in detail. Specifically, what are you planning to connect to with the Freewave radios? Do these radios have a communication protocol?
Lookout has a Modbus driver object which has both the serial and Ethernet (TCP) options.
Sorry for not being of much help.
Khalid
(3,566 Views)
Can it run in UDP also?
Whit
(3,566 Views)
The problem is with the protocol of Modbus. If you check the modbus.org site I believe it uses 52 as the port under IP to communicate. We have found the same problem using MDS radios to communicate with ControlMicro serial port RTU's. We only had limited success using IP to serial communications and ended up with serial to serial across the IP network.
Hope this helped.
JZ
(3,566 Views)
Yes, we run UDP Multi-point to point.
JZ
(3,566 Views)
