Lookout
How do I use Access in Lookout
I am trying to store either 'changed' data or 'polled' data into an Access DB.. I cannot figure out how to do either.
I have the correct statement and have been able to use SQLExec.Execute to poll data manually, but I cannot figure out the relationship to it and a Pulse timer.
Nor can I see how I can .Execute on change..
Thanks!
(3,086 Views)
Hello Michael,
I am assuming you have already taken a look at the following KB article on using SQLExec object to insert data into Access:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/4adeea04cd24ae0b862565e20002a16f?OpenDocument
To do this periodically, you will connect a Timer to the .execute datamember. First create a Pulse timer object. Then go to Edit Connections from the Object menu. Select your SQLExec object. And make the connection to the .execute member as follows:
Sql1.Execute = Timer1
To execute on change, basically you will have to come up with some logic where you end up with a logical high (trigger) when the data you're interested in has changed. You would use this logical high (instead of the Puls
e timer) to execute the SQLExec.Execute.
Hope this helps.
Khalid
(3,086 Views)
