Lookout
How to dynamically change text color in Lookout?
I would like the color of text to change depending on a different value.  How can I do this in Lookout?
I've tried finding connections to text inserts and expressions but haven't been successful.
Dave
(6,892 Views)
Accepted by davey31415
Edit the text display property, set Background Style as "Transparent".
Create a Gauge object. It is able to change color on different conditions. Put the Gauge above the text display.
Ryan Shi
(6,872 Views)
I have tried this before but it didn't work. Can you explain better?
(6,573 Views)
This way actually doesn't change the text color, but change the background color of the text. You know the Gauge is able to change color. If a TextEntry object is transparent, you will just see the text. Put the Gauge and TextEntry together, and move the TextEntry to front.
Take a look at this example.
http://zone.ni.com/devzone/cda/epd/p/id/1215
Ryan Shi
(6,558 Views)
If you want the text color to change you can 'stack' expressions with different colored text or have a static base text and an overlying expression with colored text.  The attached example might make what I’m trying to describe a little clearer.
(6,540 Views)
