Lookout
How to set an ActiveX Property
Hi
  I am having problems understanding how I can set a property of an ActiveX control in lookout. Here is what I am trying to do. I have an activex contol that shows a cctv camera's video.The video is showing up properly on my lookout screen. The name of the activex control is IVC_ax1. I need to add a push button to my lookout screen that when pushed sets the property of to:  IVC_ax1.PanRight=.05 and when not pressed it should set the property to: IVC_ax1.PanRight=.00. How can I do this I have tried several ways and have not had any luck. Any help you can give me will be greatly appreciated.
Rob
(3,369 Views)
All the available properties should appear in Object Explorer after you create that ActiveX object. Then, you just need to edit connections.
Ryan Shi
(3,346 Views)
