Lookout
How to upgrade from Lookout 5.1 Run Time Only to Full Development
A computer with Lookout 5.1 Full Development System had failed. I plan to replace it with another computer that has Lookout 5.1 Run Time Only 500 I/O points.
I have the serial code and the license number for the Full Development.
HOW TO UPGRADE THE RUN TIME ONLY TO FULL DEVELOPMENT WITHOUT UNINSTALLING AND REINSTALLING THE SOFTWARE?
I think it is quite simple to do, but I do not know how...
Best regards
(5,900 Views)
Send an email to ryan.shi@ni.com with your serial number, and the organization name you want to use with the activation. Please also tell me the IO point with the SN.
Ryan Shi
(5,895 Views)
Hello Ryan.
I do have a Lookout 5.1 Full Development Unlimited I/O license available (not in use). I just don't want to unistall and reinstall Lookout (if possible).
There should be a way to re-enter the serial number and the activation code without a 'deep' work.
If it is complicated, it would be better then to uninstall and reinstall Lookout with the new numbers for Full Development Unlimited I/O.
I'm trying to save time and efforts.
Regards.
Rudy
(5,887 Views)
Option->System->Change Registration Info
You need to input the Organization, SN, and keycode.
Ryan Shi
(5,876 Views)
