Lookout
Trouble deleting object Ver 6.0.1
I have some objects and items in DATA MEMBER CONFIGURATION that are unused but when I try to delete them I receive an message that they are still in use.  Is there a way that I can find where these are so I delete them then delete the items in the DATA MEMBER CONFIGURATION?  I need to regain the I/O points.
(5,907 Views)
You can get the connection information from Objects->Connection Browser. If one point is output to another object, it cannot be deleted until you break this connection.
Ryan Shi
(5,893 Views)
I knew this was somewhere but had forgotten where it was.  I opened it but is does not show me any of the connections for any of the objects, even when I right click and click on "show connections".
Suggestions?
(5,887 Views)
What if you double click on the object? It is supposed to show the input and output connections. And you can also double click on the input or output. Another way is to open the .lks file by text editor, and find the word of object name or data member name. But you'd better make a copy of the .lks file before you editing it.
Ryan Shi
(5,873 Views)
