Lookout
I GET ERROR "WAITING ON TIMESERVICE"
When I try to load Lookout I get a window saying: "waiting on TimeService" followed by a window saying "TimeService not Responding". Can you help me?
(3,483 Views)
The Citadel time service should be started automatically, but there is a way to fix this. In Windows 2000 (I think the directions are similar for NT and XP), right-click on "my computer" and choose "manage." Then, look under services and applications >> services. If you cannot manually start Lookout Time Synchronization (right-click and choose "start"), then it may not be installed properly; install the latest version of logos. If you can manually start the service, then you can also change the startup type from manual to automatic.
Michael Shasteen
Applications Engineering
(3,483 Views)
