Lookout
I am getting a 10-20 second delay before values are updating. ???
I am very new to lookout and very inexperienced with building screens so any help would be great.  I am building some new screens and I'm getting problems with some of my values updating.  I am using automation direct PLC's with DirectSoft 5.3 logic  and  KepDirect 5.5.  I can manually update input values with a Slide bar but the output bar that shows the % of output is about 10-20 seconds behind on updating.  Another example is a switch that I have that places a pump in manual or auto, if its in auto and I click it, the screen will take a few seconds before updating it to manual.  But the PLC and Kepdirect are seeing the changes as soon as I make one on the screen and they are showing everything updating just fine.  It just seems like the only spot its seeing a delay is in lookout.  I've tried all I know to try and everything seems to be entered in correct and tied together correctly in lookout and KepDirect.
Any advice would be appreciated.  Thanks
Message 1 of 1
(5,494 Views)
