Lookout
Installation error in fonts
I installed Teststand 2.0 demo version. All my fonts in Office are not readable. It looks like one character over other. I cant read the text. Some solution?
(3,463 Views)
You may want to post your query under Teststand section of this forum for faster response.
(3,463 Views)
Hello Garcia,
This is a weird behavior. As far as I know TestStand does not install fonts, or modify the existing ones. It might be something that happened during the installation. Did you receive any error when you installed TestStand?
Roberto P.
www.ni.com/support
(3,463 Views)
No. Im going to receive these week the last release so I can install it again. But another friend in other plant saids that every machine they installed with TestStand, has the same behavior. To fix my machine I installed MSOffice and then deinstalled it again. It fix the problem.
(3,463 Views)
Hello Garcia,
What is the OS you used and the MSOffice Version? I may need to try to reproduce it here.
Did you have any background programs running when you installed TS, such as anti virus? If yes, we recommend turning off those programs before installing TestStand. In addition, if you are using NT base systems such as NT 4.0, Windows 2000 or Windows XP, make sure you use an administrator account when you install TestStand.
Roberto P.
www.ni.com/support
(3,463 Views)
