Lookout
Invalid Argument
I am having a problem with Lookout 6.5 running on Windows 7. When I startup Lookpout running my application which was originally developed and ran on Lookout 6.2, I get 16 alarms as shown in the attachment ALARMS.png.
I also have attached UNIVERSE.png which is a screen shot from Measurement & Automation Explorer showing the database.
Any help you can provide would be appreciated.
(5,524 Views)
I have seen these errors at random, sometimes for values that are not valid.
For example if the data member is set as logical and the value is numeric, or vice-versa.  Also, if the data is null, which may happen in the case of a bad link quality or comm-fail.
Usually the process works fine
Forshock - Consult.Develop.Solve.
(5,502 Views)
