Lookout
Lookout 6.1 Team collaboration
We are using Lookout 6.1 and as couple of team members mentioned, there are no collaboration options for Lookout. Let's say several people are working on one and same project where there is a need when all are done with their parts to connect all parts and pieces together in one place.
Is there a module or a way in Lookout that allows team collaboration and if so, what is the best approach?
Best Regards,
Amil
(5,693 Views)
The only way I can think of would be to merge the work together in the source code (lks file).
Jason Phillips
(5,684 Views)
Work with Aggregates more:  Changes to common code will be updated when reloaded.
Setup your own source control system (GIT, Google Code, etc.):  Auto-archiving and version control, check-in and check-out.
Forshock - Consult.Develop.Solve.
(5,668 Views)
