Lookout
L3Pot
Hi>>>
I want to ask about how to create L3Pot and L3switch objects and from where(im using lookout6.0)?if someone tell me in steps....
thanks
MaNaL
(4,173 Views)
Manal,
See the last item on this KB article, including the NOTE:
http://zone.ni.com/devzone/cda/tut/p/id/3607
-Khalid
(4,166 Views)
thax Khalid for trying to help me. but i was asking about L3. i mean where can find it in the Lookout. and what does it mean. i knew about them from the example included in the applications folder ...
MaNaL...
(4,161 Views)
Manal,
These L3Pot and L3Switches are legacy Objects from Lookout 3.x.  You don't get to create these in newer versions of Lookout -- unless by using the INI entry mentioned in the KB article above.  Once you add the INI entry and relaunch Lookout, you will see these in the list of Objects.
Please let me know if I am still misunderstanding your query.
Thank you and regards,
-Khalid
Message Edited by Khalid on 11-09-2006 10:47 AM
(4,154 Views)
thanx khalid...i understood know..
MaNaL...
(4,144 Views)
