Lookout
Lk 6.5 Web Export does not fully hide Status Bar
Can you please fix this?
When not fully hidden (top of status bar still visible), users can select controls on the status bar, which is NOT desireable!
Ed
Message 1 of 13
(6,699 Views)
Do you mean the status bar on web client? It's not hidden, you can click to open the login dialog box.
Do you want to fully hide the status bar on web client?
Ryan Shi
Message 2 of 13
(6,694 Views)
Yes, status bar on client web page is partially visible (top edge).  Template .htm file has display size of width="1925" and height="1145" and <PARAM NAME="StatusBar" VALUE=0>.
Ed
Message 3 of 13
(6,692 Views)
I don't understand your problem. Attached is the status bar on web client, which is exactly the same as the one in server software. It's not hidden.
Ryan Shi
Message 4 of 13
(6,687 Views)
Ryan, you have this backwards:
Client task bar is supposed to be fully hidden but is only partially hidden.  See attached image where there should be NO status bar.
Message 5 of 13
(6,681 Views)
I didn't notice that check box for status bar in web client export configuration.
So, you didn't check "show status bar", and exported it, but you still saw half of the status bar. This is your problem, right?
What's your OS? and monitor resolution?
Ryan Shi
Message 6 of 13
(6,669 Views)
Yes, that is my problem.
Windows 7 x64
Screen resolution doesn't seem to matter.  This particular page has been run in both 1920x1200 and 2560x1600 with same results.
Message 7 of 13
(6,666 Views)
Verified same problem exists on clients with lower screen resolutions
Message 8 of 13
(6,659 Views)
Ryan,
Any chance of getting this problem fixed soon?
Ed
Message 9 of 13
(6,648 Views)
The problem is that we cannot reproduce it... I tried different computers but got the good result.
Could you upload your exported web client files including the html file and process file to our ftp? ftp://ftp.ni.com/incoming
What's your web client computer's monitor resolution?
Ryan Shi
Message 10 of 13
(6,645 Views)
