Lookout
Logging an ASCII signal to Excel through Lookout
I am trying to use Lookout to log a serial data  communication. I am actually
getting the signal to Lookout, however the ASCII signal is sending each
individual digit separately instead of as a string. Therefore,  when it logs in
excel, it places each digit  of the number in a different cell.  For instance, the number that flashes through my Lookout display will be 30.50 (flashing each digit seperately, one at a time. When the number logs to excel, there will be a "3" in the first box, "0" in the second row, "." in the third, and so on.
Is there a way
to get around this?
Jared
Message 1 of 35
(7,412 Views)
Just wanted to add that I am using Lookout 6.7.1, and that the ASCII signal I am trying to log is coming from a closed system that I do not have access to to change the signal type.  Hope this clarifies any questions.
Thanks again for any help.
Message 2 of 35
(7,411 Views)
Anybody?
Message 3 of 35
(7,342 Views)
Can you give an example of the data from a serial log file?
Forshock - Consult.Develop.Solve.
Message 4 of 35
(7,337 Views)
Attached is a screenshot of how the file is logging.  It is logging a weight and a length.  The weight signal is logging fine, but the length signal logs each digit separately.  I need to get the signal to where the length will all log into one cell paired with it's corresponding weight.  Even in Lookout, I created a display on the screen to show the length, and each digit of the string flashes by - one right after the other.
Thanks for any help,
Jared
Message 5 of 35
(7,334 Views)
What is your response format?
Please log the serial port data (Options > Serial Ports)
Message 6 of 35
(7,317 Views)
Com3
9600 baud
8 data bits
1 stop bits
None parity
Thank you
Message 7 of 35
(7,313 Views)
Are these measurements coming from separate instruments or what?
I think Mr Forshock is asking how the data sent from the device(s) is structured, not what the com port parameters are.
I'd suggest you take a good look at the structure of the data stream using Hyperterminal in Programs| Accessories|Communications|(in XP), log it to a file and use a hex editor to see what's really being sent.
Message 8 of 35
(7,299 Views)
The two signals are coming from different instruments.  I will try to use Hyperterminal to log the signal.
Message 9 of 35
(7,297 Views)
Here is the signal I get in Hyperterminal in the first "column", then converted to Hex right next to it. Is this what you are asking for?
Message 10 of 35
(7,293 Views)
